factory center speaker replacement
  • 4
d_dfw
DFW
The 3 1/2 inch center speaker in my Ford Taurus shows 25 watts / 8 ohms and I would like to replace it. All the replacements I find are 4 ohm and rated at various RMS. Such as this 5 - 25 RMS Infinity 3002cfx.
According to this website, Speaker Impedance vs Power Output, it appears that 25 watts is peak power for 8 ohms. And RMS would be 1/2 peak. So, I'm thinking I'm getting about 15 watts to this center speaker. And would I get about 25 watts if I replaced it with a 4 ohm upgrade, due to the increase in current?
Do you think a 4 ohm / 25 watts RMS replacement would be a good idea?
I wasn't planning on adding an amp yet. From this speaker, all I can really pick out are vocals, and I was hoping to hear more of the upper range.
Once I can figure out the wiring of the front speakers then I would like to add an amp. There's the center, two A-pillar tweeters and the two front doors.
I just replaced the front doors with the Infinity Kappa 682.9cf which handle up to 100 RMS. And most of the other replacements I've looked at get up to about 100 RMS, except for the center. So maybe the center can stay on the factory amp, because it doesn't appear that aftermarket amps push less than 100 watts.
i agree you want to stay with an 8 ohm speaker. the factory amplifier may be providing a bandpass crossover to that speaker - in which case it doesn't matter what speaker you use. since you have the speaker removed, test it to see if you get full range from it. if not, then you can get a Dayton Audio or Peerless or Tang Band speaker to fit in 8 ohms that plays to 15kHz.
I own a 2016 Lincoln MKT. I purchased a FORScan chip to increase the power handling of my aftermarket speakers. However, I'm having trouble...
If you buy a replacement OEM Radio Harness the colors will match up then you can use a wiring harness to connect to that. According to a few...
Then you need what I listed. You also need to find out if your Honda Element has an OEM amplifier or not. And if you have steering wheel controls...
d_dfw
d_dfw
DFW
d_dfw
just call me KeV
    Jun 2, 2024
just call me KeV
    Jun 2, 2024
