Factory System, Aftermarket Powered Subwoofer
  • 4
njknittle
PA
Hello all, its been awhile. But anyway Im looking to purchase a Rockford Fosgate P300-12, to give my system some extra bass. Factory subwoofer just isnt cutting it. The car is an Audi A4 (2010) with a stock stereo. It does however , have a factory amp, with a subwoofer as i previously said. My question is, should I use a LOC or the High Level Input on the Powered Enclosure? And which either one you recommend, do I just T Tap into the existing factory subwoofer wire, or cut it completely and splice it?
On the High Level Input as well as an LOC, there are multiple wires. I just want to hook the aftermarket powered subwoofer up. Do I have to utilize all the wires?
Thanks!
How come people seem to view but never respond?! //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
Because its the only powered subwoofer on the market that strikes my interest. Just need some good extra thump.
My vehicle also has Bose as the premium option. The same thing was said about climate control for the RX 8. A previous owner replaced the HU...
4
Audio Control LC2i Pro, and amp/sub combination of your choice. You connect the LC2i to the rear speakers and get power from the amp's power. It...
I own a 2016 Lincoln MKT. I purchased a FORScan chip to increase the power handling of my aftermarket speakers. However, I'm having trouble...
If you buy a replacement OEM Radio Harness the colors will match up then you can use a wiring harness to connect to that. According to a few...
njknittle
njknittle
PA
njknittle
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
