False floor/amp rack in my Explorer
U would know if u had the problem
exactly what my truck is doin... feels like the tranny is going to fall out going into reverse..... have yall found a solution?
Should have reworded that one, where do I check the box for tranny/rearend problems...
This has turned into a pos explorer thread
I'm not sure if it was just luck of the draw, or just people beating the crap out of their vehicles. But, I've heard of the trans going bad in Explorers at 35K, 140K, and anywhere in between. Though, I've not heard of them lasting longer than 140K! I've got to start a transmission savings account, now!
well the banging in reverse is def the trans cause you can put it in reverse then 10 sec later it slams then starts moving with some shaking in the worst situations
Man, just hearing someone say that when they're at 40K is just shitty. //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif I guess Ford royally ****ed up with this one
no i never said i got a problem. I am saying i expect it not to fail on me thats all
whatever happened to the pics inside the port?
Forgot about it. I'll get that tomorrow //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
edit: lemme dig up old pics see if i can find it
edit 2:
No reason you can't get the sound you want with ported or passive radiator but if you have no ability to tune the mass of the passives you will...
If you order directly from taramps in brazil you can get a smart 3k for $259 shipped...
I too generally use the factory carpet to make my templates. It's also a good idea to put layer of butyl damping material under the MDF too...
816
174
362
JarvisB
JarvisB
JarvisB
MI/DC
JarvisB
