False wall/loading wall?
You could set it up normally facing the rear. The for the false wall, build a frame and use a mesh wire to fill the holes. Throw carpet over that. Should be strong if braced properly and provide the sub with more air space. I don't believe this would effect sub level waves and should solve all problems.
I don't see what "problems" would occur with it loading off a piece of MDF. It basically acts like the back wall/lid of the trunk, it's just moved up a foot or two.
If you order directly from taramps in brazil you can get a smart 3k for $259 shipped...
No reason you can't get the sound you want with ported or passive radiator but if you have no ability to tune the mass of the passives you will...
Ok then 11 cubes will be fine. Keep in mind the f/s of those woofers is about 28 hz, so you if you tune really high above that, the woofers can...
What would you recommend using for the roof then ? Should I do just the bpillar or the whole roof ?
907
MONSONwarrior
Premium Member
Constantly Rebuilding...
MONSONwarrior
Baton Rouge, LA
MONSONwarrior
    May 31, 2024
    May 24, 2024
