Fan on amp comes on a lot
So how does Agm batteries help with voltage drop? Is it the extra amount of reserve they have?
And is there a way to measure how much amperage my Amp is pulling at full tilt?
I have a volt meter and a clamp meter.
AGM batteries usually crank more than standard batteries.
If you have a DC clamp meter, just set it to peak/hold and full-tilt on a few songs. If you have a standard AC clamp meter like most people, that won't work.
So I checked the voltage drop at the amp with a few different bass heavy songs and the truck idling and it mainly stays around 13.0-13.25 but a few times it did dip down to 12.75.
This was with a craftsman multimeter set at D.C. Voltage.
12.75 was the lowest I seen while idling on a bass heavy song at full blast.
Someone said as long as you don't go below 13.0 your fine, is 12.75 a danger to the amp?
12.75 is about battery resting voltage. Your alternator is just not keeping up with current demand.
I don't like voltage drop, but 12.75 isn't serious danger.
Do you think the voltage drop would get better if I replaced the 4 gauge power wire with 0 gauge power wire?
It might help a little but don't expect a huge increase.
Note: I just don't understand why some people don't give their amps suggested power/ground wire size. Instead, they undermine them.
There are all kinds of Ideas out there by a search on the internet these days. Find the one that works for your situation and budget and...
4
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
137
6
368
  • Locked
NVX MVPA1 Best tiny amp Installed a bunch, but have one pushing a sealed 12 @ 2ohm in my daily beater Can bump it all day long and barely gets...
4
666
Amp
This tested well on youtube - not familiar with the brand but it is a pretty standard china build house amplifier...
5
483
Ekisaacs
Ekisaacs
Missoula, Montana
adulbrich
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
