Fighting with ford factory DSP, possible junk sub.
Here is a guide to FORScan for those interested in modifying their Ford stereo'shttps://docs.google.com/document/d/1-8dKaS_Spu4Zw4hV_CrKC4tLoP9G8yejqegF1wxIqxY/edit
ODB connector-
Cheap wired ODB connector
https://www.amazon.com/bbfly-BF32302-modified-Windows-ELMconfig-Forscan/dp/B01N9R9QS2
Wireless but more expensive ODB connector
https://www.amazon.com/ScanTool-426101-OBDLink-Bluetooth-Professional/dp/B006NZTZLQ/ref=pd_bxgy_263_img_3?_encoding=UTF8&pd_rd_i=B006NZTZLQ&pd_rd_r=TR0KHKDH963QW32CVMNJ&pd_rd_w=qQU02&pd_rd_wg=nMV8u&psc=1&refRID=TR0KHKDH963QW32CVMNJ
This worked on my 2017 F150 and 2017 Mustang
Variable Line Level Preamp Outputs From ACM (for adding aftermarket amp without sound clipping)
ACM727-01-01xx5Axxxxxxxx
ACM727-01-0200xx
APIM7D0-01-012xxxxxxxxxxx
Source
https://www.f150forum.com/f118/2017-low-level-acm-reprogram-audio-build-372285/
This works for 2016 and older (note the xx59 instead of xx5A)
This mod can be done with FORScan w/ODBLink MX Adapter:
727-01-01 xx59 F8x8 xxxx - Enables Line Level with Optional Subwoofer (Aux 1) and Front Center (Aux 2) Outputs Enabled*
727-01-02 00xx - Disables Factory EQ Processing
(ACM As-Built)
* This string breaks down as follows:
5 = Variable Line Level Audio Output
9 = Enable External Subwoofer (AUX 1) and Internal Amplifier (Aux 2) (0 - Disable)
F = Disable Open Speaker Circuit Detection (w/Active FM Radio Antenna - Otherwise use a D)
8 = Front Tweeters Present
8 = Aux 1 Type: Mono Subwoofer and Aux 2 Type: Front Center
7D0-01-01 2xxx xxxx xxxx
(APIM As-Built) - APIM change required only if you have Sony DSP before completing this mod.
Source
Variable Line Level Preamp Outputs From ACM (Factory Radio) For Amplifier Upgrades
I have a 2014 SHO. Do you see a option to turn off the alternator gas savings mode? Want to have the alt on all the time.
Thanks
Sent from my SM-N950U using Tapatalk
This is from the guys over at the fusion forum but it may work on your Taurus
Battery Monitoring System:
726-04-01 (2014+ MY) xxxX xxxx xxxx
Note: I recommend disabling BMS if you have an aftermarket stereo system. Especially if your battery charge is consistently low. Alternator always on.
(BdyCM)
2 - Enabled (Default)
0 - Disabled (May lower fuel MPG)
Source
https://docs.google.com/spreadsheets/d/1yax6zfhZYj2joBczEeruqKh9X5Qhee3C0ngilqwTA7E/pubhtml?gid=0&single=true
Unplugging the hall effect sensor ring on the negative battery wire is said to have the same effect, I cannot confirm this though.
726-04-01 (2014+ MY)xxxX xxxx xxxx
(BdyCM)
Source
Awesome!! Thanks dude. Exactly what I need. I hope it's there for my sho but I think it would be.
647
Ahhh, I had it in my head that it was 1 ohm stable for some reason.
41
One fuse (the 300) goes close to the battery to protect the power wire...then close to the amp you'll add another fuse (whatever size the...
29
4K
It is in eBay. It is a bit more complicated. You clip off the gray blocks on your radio's harness and splice in the new harness by color matching...
There is one more thing; you said you will be using the OEM amplifier for the front stage. If that is the case, then you may need an vehicle...
174
stones
Senior member
stones
Sask
evilmonstertruk
audiobaun
    May 19, 2024
    May 19, 2024
