First Big Amp NEED Help
mustangkids
I've purchased a Sundown NS-1 and it doesn't have internal fuses and I'm scared of blowing it up. In the manual it says that the amp recommends a 650a fuse and they don't make 650a fuse also the amp has 3 sets of ground and power do all 3 power cables need to be fused off my second battery?
Each lead (wire) will need a separate fuse to them. 200 amp each should be fine. Wire it up like this: From the amp, pos about 16-18" or so, then fuse, then the rest of the pos wire to wherever.
A lot of bigger mono amps don't come fused because there's prob not enough room on the side of the amp to put 25 30 amp fuses in it.
Black widows sound amazing done right for sure...I remember seeing a quite a few cool looking and good sounding loudspeaker setups when I was in...
16
Wow, kinda baffled here. Once you get the tune right. You don’t need to mess with it. However, A bad tune you will. You may have different type...
16
I will still find the blame..Bad tool, cheap connectors, junk wire..LOL 🤣 🤣 I didnt have enough B12 this morning is my favorite
23
3K
mustangkids
mustangkids
Bozeman, MT
kr15
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
