For those who use Toolmaker battery terminals: quick help please
  • 5
FML
Extreme Lowwwwwws
383
Idaho
Im Buying my 2nd battery for the back today. I already have a new Duralast Platinum AGM under the hood, so im going with another for the rear. The h8 is the biggest one other then the 31 (out of stock) .
Im worried about the recessed battery posts. I have these toolmakers being delivered. Will they work with the style of this.battery? You can obviously only run these terminals 2 ways off that battery, but looks as if it will block the set screw to tighten em to the battery post? ? I need to know if anyone else has run into this, if it's a problem or not. If som ill just get the smaller group 65 with normal posts up top.
May need to cut an allen-wrench or replace the set-screw with a bolt that has the same threads.
I used a different style battery terminal setup for my recessed top-posts.
I was thinking maybe flip them over and see if they'll fit
Thats exactly what I was thinking.
Nobody is going to know for sure, you'll just have to put them on and try
Uhm, only 1 problem with that: the batteries arent in stock. I cant just take my terminals down and test to fit. I'll have to order, then return then order again for the right one if not.
And thats why i asked for "people with experience with toolmaker battery terminals " to chime in. People without that experience, your guess is as good as mine and therefore useless in my query.
Had a set of Ecplise 6x9's back in the day in my '99 Grand Cherokee. The SE8495s iirc those were so sweet sounding. Wish I hadn't sold the GC with...
609c is very good for their price. I haven't used the Pioneer but I'd figure if they're comparable price they should perform similar.
actually have 4 coaxial in the doors. so better for me to procure 2 comp and put in the front door and send the 2 front coaxial behind the back seat.
161
FML
Extreme Lowwwwwws
FML
Idaho
speedyjuarez
    Jun 1, 2024
    May 31, 2024
