FS: (2) DLS A2's
  • 4
Argent Audio
(2) DLS A2's
Used, no flaws, working perfectly, only marks on the mounting feet. Only been mounted once.
$200 shipped each or $375 shipped for the pair
RMS Power Rating:
4 ohms: 85 watts x 2 chan.
2 ohms: 145 watts x 2 chan.
1 ohm: 220 watts x 2 chan.
Bridged, 4 ohms: 290 watts x 1 chan.
Bridged, 2 ohms: 450 watts x 1 chan.
Pulse Width Modulated MOSFET power supply
2 or Mono channel operation
Heavy duty aluminum alloy heatsink for extreme heat dissipation
2-Way protection (Thermal & Current)
Gold-plated RCA level inputs
Gold-plated screw terminals
Input Sensitivity: 0, 2 - 7 V
Variable high-pass filter (20-200 Hz)
Variable low-pass filter (50-125 Hz)
Subsonic filter (20-200 Hz)
Signal-to-noise ratio: >100 dB
Damping factor: >200
Frequency range: 10-50,000 Hz
Input impedance: >10,000 ohm
Weight: 8.16 lbs
Dimensions: 9-7/16"D x 10-7/16"W x 2-7/8"H
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
Argent Audio
Argent Audio
Morgan Hill, Ca
RaveShow
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
