SOLD fs: 2 Kenwood 12" shallow mount Subs and Ken Amp
ssackett
Evo Audio
4,863
CA
Got 2 like new 12" Kenwood Excelon KFC-XW1200F SVC4 shallow mount subs and a Kenwood 8104d mono block amp. Also have custom made sealed box that fits under the rear seats of a 2008 Quad Cab Chevy/GMC truck. Only local pick up for the enclosure. PM me for price.
$125 shipped for each sub plus pp fee
$115 shipped for the amp plus pp fee
Amp Specs:
Mono subwoofer amplifier
300W x 1 at 4ohms (20-200Hz 0.5%THD)
500W x 1 at 2ohms (100Hz 0.8% THD)
CEA-2006 compliant
Bass Boost f=40Hz Gain 0 - 18dB
Class D Amplifier Circuit
Aluminum Die Cast Heat Sink
Power MOS-FET Switching Power Supply
Speaker Level Input and outputs
Signal Sensing Turn-On
2ohm Load Capability
Line Output Terminals (RCA) for Extension
Blue Illumination
Gold Plated Power & Speaker Terminal
Built-in Variable Low-pass Filter 50-200Hz (24dB/oct)
Built-in Infrasonic Filter 15/25Hz (18dB/oct)
Fuse rating: 40A x 1
8-gauge power and ground leads recommended - wiring and hardware not included with amplifier
11-1/16"W x 2-3/8"H x 9-7/8"D
** Pics uploading now
I have 2 more questions about the Kenwood DDX9907XR / DMX907S radios. 1. If I am listening to a source and have that particular source displayed...
Honestly I don't think it would be hard for them to make it where you use android auto AND your own music source. They made it able to do so...
5
636
@Deiimos Hit it on the spot from the beginning of a bad ground. Excellent! Im happy to hear that you went through some procedures to locate the...
20
I got it to work, I was plugging in the subwoofer while the amp had power. I unhooked the remote turn on lead, then all speakers plugged in, then...
4
879
ssackett
Evo Audio
ssackett
CA
ssackett
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
