SOLD FS: 2 Kicker 15" L5 subs and 1 MA Audio HC2502 2500 watt amp
VTS
I have two 15" L5 kicker subs that are dual 4 ohm voice coils and are in mint condition. They were both used for about a year and then put in storage. I have tested them and they are in perfect working order.
The amp is a MA Audio HC2505 amp and the specs are as follows:
Stereo
--@ 4 ohms 2 x 250w rms
--@ 2 ohms 2 x 450w rms
--@ 1 ohm 2 x 750w rms
--@ .5 ohms 2 x 1250w rms
Bridged
--@ 4 ohms 1 x 900w rms
--@ 2 ohms 1 1500w rms
--@ 1 ohm 1 x 2500w rms
Dimensions:
11-1/2" Wide x 2-1/2" High x 24-3/4" Long
The amp is probably an 8-9/10 in cosmetic condition. It has a few marks here and there on it. It is kind of hard to see them since its all chrome. The amp has been tested as well and is working great.
Looking to get 125 each for the 15s and 150 for the amp. Here are the pics (sorry they appear to be upside down):
View attachment 26519284View attachment 26519283View attachment 26519286View attachment 26519285
If you guys need any more pics, I can take some more and put them up. Just let me know.
ill trade u a reconed 10 " DC AUDIO LV4 weight is 35+ pounds can do 1500 to 2000 rms with good electrical and has 2 to 3 mins of play time on it ill trade you for the amp if interested
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
722
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
low level when using RCAs so that knob should be pushed out. The crossover turn it all the way right and use the one on the head unit and set it...
5
VTS
VTS
nashville, tn
mossberg385t
1aespinoza
    May 23, 2024
Doxquzme
    May 22, 2024
