AudioAnonymous 10+ year member
Item:
One Cactus Sounds K9S
Specifications:
Model K9s
4 Ohm Power: 2750W
2 Ohm Power: 5100W
1 Ohm Power: 9300W
1 Ohm Power 16V: 11000W
1 Ohm Power 18V: na
Freq Response: 20-250Hz
Signal to Noise Ratio: 95dB
Damping Factor: 250
Input Sensitivity: 6V - 0.2V
Low Pass Filter: 35-250Hz
Subsonic Filter: 10-50Hz
Bass Boost: 0-9dB
Master/Slave Connections Linked to 2 Ohms, Thick 3oz Copper Traces, 3 x 0awg Connections, 54.59lbs
Heavy Duty Aluminum Heatsink
Oversized Power Terminals
24dB/Octave crossover
3oz Copper PCB to Support High Current Flow
Utmost Stability for Daily Driving
Oversized 0 Gauge Power & Ground Terminals
2.5mm Thick Copper Traces
Description/Condition:
Used but not much. There's some marks where you put the screws in to mount it down but that's normal wear and tear. To be honest I haven't looked at it super close but I would give it a 9.0/10 for cosmetics and 10.0/10.0 for performance.
These amps are known to put out more power than rated and at a lower voltage than tested at.
1600 shipped/insured, or 1500 picked up
Specifications:
Model K9s
4 Ohm Power: 2750W
2 Ohm Power: 5100W
1 Ohm Power: 9300W
1 Ohm Power 18V: na
Damping Factor: 250
Bass Boost: 0-9dB
![IMAG0017.jpg](/proxy.php?image=http%3A%2F%2Fi6.photobucket.com%2Falbums%2Fy231%2FAudioAnonymous%2Fvan%2FIMAG0017.jpg&hash=d6838742dca81f546f6277f95a931482)
![ma.jpg](/proxy.php?image=http%3A%2F%2Fi6.photobucket.com%2Falbums%2Fy231%2FAudioAnonymous%2Fshows%2Fma.jpg&hash=c11c8b9fe4999ccb0a1da1f07309b765)
![100_1806.jpg](/proxy.php?image=http%3A%2F%2Fi6.photobucket.com%2Falbums%2Fy231%2FAudioAnonymous%2Fshows%2F100_1806.jpg&hash=6092cb0324d61646f724bb75b37ae267)
