FS: Cadence Dakota mono block - 1200w RMS @ 1ohm
  • 1
Trixter
Keepin it Simple
Cadence Dakota (United Series)
I Purchased this amp new to replace another amp (Cadence A7hc) that went out on me. However, I was able to get my A7 fixed so now I have no need for this one. The only play time it has was while the A7 was in the shop and this Dakota only has about 20 hours of play time on it.
Purchase Dakota on Aug 2nd (received about a week later). Got A7 back from Cadence on Aug 29th. The Dakota has been in a box since.
I have it listed on Ebay as well: Cadence Acoustics Dakota 1200 Watt RMS Class D Mono Block Amplifier | eBay
I bought it for $310 shipped. I'd like to get as close to that as possible since it is practically still new. Make an offer.
Ships from Kenosha WI 53143
Specifications:
• 4 Ohm RMS Power: 400 Watts x 1
• 2 Ohm RMS Power: 600 Watts x 1
• 1 Ohm RMS Power: 1200 Watts x 1
• 2 Ohm Twin Amps Bridged Power: 2400 Watts
• Minimum THD:
• Frequency Response: 10Hz – 500 Hz
• S/N Ratio: >100dB
• Damping Factor: >220 @ 100Hz
• Dimensions (L x W x H): 15” x 7.25” x 2.5”
Features:
• High Speed MOSFET Power Supply
• Studio-Grade Bipolar Output Stage Transistors
• Fully Adjustable 12dB / Octave Crossovers
• Low Pass: 10Hz – 50Hz
• Fully Adjustable Bass EQ Boost Control
• Mute and Delay Soft Start System
• Full IC-Controlled Protection Circuitry
• Fully Adjustable Subsonic Filter
• Adjustable Bass Focus Control
• Dashboard Bass Remote Control Included
• Master / Slave Amplifier, Daisy Chain Bridging Capable
• 8 Volt Pre-Amp Circuitry
• RCA Pre-Amp Line Output
• Phase Control Switch
First of all you would want to verify that it works. Next, don't expect to get much out of it. There's a rather finite life expectancy on...
Get your Coupon RIGHT NOW!!!🥳🥳🥳 Let’s celebrate the upgrade of Cadence Sound Website! Take this chance to get the 10% OFF coupon which has no...
  • Locked
NVX MVPA1 Best tiny amp Installed a bunch, but have one pushing a sealed 12 @ 2ohm in my daily beater Can bump it all day long and barely gets...
4
661
Trixter
Keepin it Simple
Trixter
Colorado Springs, CO
Trixter
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
