FS Crunch GP3000D
350zspl
WPB Florida
GP3000D Ground Pounder Crunch
Clean & Pristine Condition
Functions Perfect
Rated
750 x 1 @ 4
1500 x 1 @ 2
3000 x 1 @ 1
$325 Shipped & Pay Palled Lower 48
Copied from the net
Depending on your battery set up this amp will make an ungodly amount of power. With a 12volt battery set up dropping to 11.5 volts the Crunch GP3000D Pro made 2850 watts at a 1.03 ohm reactive. That's 4 12volt batteries. If you can get the voltage up the amp will make much more. By just starting the car and using the high amp alternator (starting at 16.1 volts and dropping to 12.3volts), the 3000 made 3732 watts. That's crazy isn't it. THAT'S NOTHING! I hooked it up to a 16volt battery set up and it just went crazy! With the battery voltage dropping to 15.7 volts with a 1.4 ohm reactive this monster made 4640 usable watts
Funny was just looking around to see if anyone had these. Amazing amp, use to own one personally and is a monster. Might be the best amp crunch has made the last 15 years. A true diamond.
Thank you , it is the best as far as power goes, that they ever made by far .
Can Be Strapped ( Master / Slave ), Can run 14 V for 3000+ watts , or 16 V for 4000 + watts
Can be run at .5 ohm with the correct electrical .
I ran this at 1.6 ohm , with Voltage never below 13 V.
Never had any issue's, its really mint.
$325 to your door
Thank you Bro
i have very nice boxes from my Sundown purchase to pack up the ground pounder for safe transport to its new owner
350zspl
350zspl
WPB Florida
350zspl
maylar
    Jun 2, 2024
    Jun 1, 2024
