Fs) Digital Designs amps, 3 m3as and 2 m2as, **VIDEO VIDEO VIDEO!!!***
cdimic25
2 New M3a
1 Used M3a
2 New m2a
The M3a has been our most popular high powered amp for many years. The M3 was never designed for spec power, but was one of the first amps in this power range to utilize a high capacity quad power supply and rock solid output section. The M3a continues the tradition delivering over 3000 Watts of long term, SQ quality, RMS power at alternator charging levels. The M3a has been the go-to amp of choice for high performance sub systems.
Here are DD's Conservative specs...
Bridged NA
Channels 1
Cont Power at 1 Ohm 2200W x 1 @ 12v
Cont Power at 2 Ohm NA
Cont Power at 4 Ohm NA
Damping Factor NA
Dimensions (Inches) 21.5L x 9.13W x 2.5L
Dimensions (Metric) 546.1L x 232W x 63.5H
Dynamic Power 4000W x 1ch
Efficiency Thru Output 87%
Input Sensitivity 0.15V - 5V
Shipping Weight 21 lbs
S/N Ratio >100dB
Tested THD ≥1%
Tested Voltage 12v -14v
Variable Bass Boost 0-6dB @ 45Hz
Variable High Pass Filter NA
Variable Low Pass Filter 20Hz - 200Hz @ 24dB/Oct
$650 Shipped obo for New M3a
$575 Shipped obo for the used M3a (it has 0 marks on it its perfect!!!)
$450 Shipped for m2a
USPS, they need the money so i use them!
Item Pictures: http://www.youtube.com/watch?v=rjyMLvaJniw&list=UUoPctu88Gg9By-MS-7U-h4A&index=2&feature=plcp
There's a Video 1st post of the last M3A it's the one out of the box with no badging on it. It's mint except for mounting marks on the feet. Info for M2A as follows 2200rms real world power BTW.
Model
M2a
Cont Power at 2 ohm
1040W x 1ch
Damping Factor
Cont Power at 1 ohm
1600W x 1ch
Dynamic Power
2920W x 1ch
Efficiency thru Output
Dimensions - mm
400L x 232W x 63.5H
Dimensions - inches
15.75L x 9.13W x 2.5L
Signal to Noise
>100dB
Shipping Weight
15 lbs
Thanks spl! The m2a is a nice powerhouse. I've clamped the few I've seen hooked up and saw around 2400-2600.
I think they will I bought 2 of his and compared to my single AB500.1 these pull little to no current at the volumes I played my AB at! He only has the M2a's left but judging from the performance of the M3a's you be thoroughly satisfied!
So fomoco365 if your interested in a DD amp while your running stock electric just pick up a M2A. Should do more then well for you!
I'd say it would be a little bit of a stretch. I have a Batcap 2000 if interested that I could toss in as well.
I used to have a pair of dd audio redline 608s, for eight inch subs they were very impressive, at least until that ole upgrade bug bit anyway. I...
7
4K
I use K3b to rip cds and for converting to any file extension I use Sound Converter or Soundkonverter on a Linux machine but you should be able to...
15
That makes sense. I took it apart today. It doesn't look too impressive but it should be better than the head unit. I'm going to install something...
8
cdimic25
cdimic25
SPL KID
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
