Fs Digital Designs Z1
Item(s) for Sale:DD z1 with bass knob.
Specs:1 x 3000W @ 1 ohm (14.4V)
1 x 5000W @ 1 ohm (16V)
Efficiency:
Dimensions: 24" x 12" x 2.76" (610mm x 285mm x 70mm) 35 Lbs
12 Volts:
4.6 ohms = 2279W
2.3 ohms = 3405W
1.15 ohms = 4188W
14.4 Volts:
4.6 ohms = 3042W
2.3 ohms = 4461W
1.15 ohms = 5358W
Item(s) Description/Condition: Used/ great condition
Price:$600
included
thanks forumcop, now please stop spamming my threads.
Lol, im not doing either of those 2 things.
I just hate to see other people get burnt. Not trying to bust your balls here, but you're asking a lot of money for what will most likely be a blind sale on the buyers end.
**Edit. You added the photos now. Much love~
But yeah again, cool amp, Glws
Honestly, not a bad price
I agree, was referring to the sale in general. If i was sending $10 for a pair of RCA's, id be less concerned with not having proof of ownership photos. Thats all
Not interested in the amp, but just gonna say the power rating you put does not make sence.
5000 @ 1 ohm via 16v
Then on detailed power rating you put 14.4v = 1.15 ohms - 5358watts.
Anyway was just interested on seeing power ratings.
I think he is referring to clamped power. These where still in the cheater amp era. The end of it anyway.
[quote name='CerwinVega_Fan']Has it ever been repaired?
Or is there anything f wrong with it now?[/QUOTE]
it has never been repaired to my knowledge, im not the original owner either. this amp was digital designs 1st big power amp that was released in 2007. nothing is wrong with the amp, works fine, im just too old for bass. only thing that is wrong is i seem to have misplaced the hex set screws for power and ground. called dd today and they said it was a 10mmx1.5x15 screw. trying to find some screws locally currently.
[quote name='los33']Not interested in the amp, but just gonna say the power rating you put does not make sence.
Sent from my Z970 using Tapatalk[/QUOTE]
funny you should ask, but the original specs from dd were 3k @1 ohm @12volts and 5k@16 volts and known to be under rated. if you were around in 06-07 this was the amp to be competing with at least in what was street classes. the other specs that you see are tests from peter t in sweden from the old soundpressure days. his word was followed like the gospel and was a true ambassador for dbdrag globally. the specs that are posted are what he was getting from the z1 in his many tests.
I think he's wanting to see that the board is clean (free of burn marks). It's good to verify before a large amp purchase.
You are correct, just want to make sure nothing is burned or out of place //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I used to have a pair of dd audio redline 608s, for eight inch subs they were very impressive, at least until that ole upgrade bug bit anyway. I...
4K
I use K3b to rip cds and for converting to any file extension I use Sound Converter or Soundkonverter on a Linux machine but you should be able to...
15
730
That makes sense. I took it apart today. It doesn't look too impressive but it should be better than the head unit. I'm going to install something...
rickmandick
Amherst, Ny
rickmandick
    May 18, 2024
    May 16, 2024
