FS: Sundown Audio SAX 100.4 D ***********************
  • 4
350zspl
WPB Florida
The version with 3 x 30 amp blade fuses , not the newer version with 2 x 40 amp blade fuses
Near Mint Very Lightly Used , Was Tie Strapped So Mounting Feet Never Had Fasteners & Remain Unblemished
I bought a new SAX-100.4 V.2 ( That Said The Amp For Sale Today Will Come With My New Amps Double Boxed Set Including Everything Pictured )
Outer Sundown Carton
Inner Sundown Box
New Un-used Bass Knob Wire
New Un-used Bass Knob With Clipping Indicator & Power Light
Inner Plastic & Foam
Amp Brings A Printed Owners Manual From This Link :
http://sundownaudio.com/product-manuals/SAX504_1004_1252.pdf
Amp Specs
Rated power output
----RMS power, 4 ohm stereo 100W x 4CH
----RMS power, 2 ohm stereo 160W x 4CH
----RMS power, 4 ohm bridged 320W x 2CH
Signal to Noise Ratio >90dB
Low pass frequency crossover
50Hz~5kHz (CH1&2)
50Hz~5KHz (CH3&4)
(50-500 with x10 switch)
Selectable 12 or 24 dB slope
High Pass Crossover
50Hz~5kHz (CH1&2)
50Hz~5kHz (CH3&4)
Variable Subsonic Filter 10Hz to 500Hz
Frequency Response 10Hz ~ 40KHz (+/-1dB)
Bass Boost 0~18dB
Variable Bass-Boost Frequency Control 35Hz to 120Hz
THD@RMS Watts
Channel Separation 75dB
Fuse Rating 30A x 3
Input Sensitivity Variable 200mV~6V (+/- 5%)
Dimensions 252(W) x 58(H) x 480(L)mm
$300.00 Inclusive Of Pay Pal Fees
Buyer Pays Actual Shipping Costs
Is American Bass better then Mmatts? Again I'm in love with quality and smoothness with alot of power and so far I'm Does the ABs have better...
12
Some of the NVX stuff seems alright, but the amps, especially the higher end ones, they seem suspect and sometimes show stats that straight up say...
13
5K
350zspl
350zspl
WPB Florida
350zspl
maylar
    Jun 2, 2024
Doxquzme
    Jun 1, 2024
