Fuse and distribution question
  • 4
heydude348
I am running 1/0 to the rear of the vehicle to an additional battery. What would be the best dist. block (1/0 in, 2 4awg. out) in your opinion?
Also, should I put a main line fuse before the additional battery or just come off thye battery with the dist. block and fuse protect from there?
You need to fuse no more than 12 inches from the front batt + AND no more than 12 inches from the rear batt +. From the dist block (0 in and 4 out) you need to fuse each 4 going to each amp.
It would be cheaper, it might be easier to find a place to mount it, and you would have a ton of options if you just do two, 3 slot fuse holders...
4
627
My bad, yes, I read them each as having two 4ohm coils. The JBL diagram left a bit to be desired, IMO. ;) And a double yes, thought U was talking...
9
I plan on getting the fuse to run as a front sub/midbass in my kick panels...I've heard they sound good but you definitely wont get mirror shaking...
heydude348
heydude348
Tampa,Fl.
big scott
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
