gain on amp
  • Thread starter <mike>
  • Start date
  • Replies 3
  • Views 2K
  • 1
<mike>
Guest
I have an old Kenwood 608S amp and I was wondering if anyone knew how to build an external gain control, so I can control the gain on the amp from the front of my car. Thanks and happy holidays.
It might just be better to build a gain control into your amp-either way you're gonna need 2b handy with a soldering iron and stripping coax, as well as careful to keep your exposed signal leads shielded as best as possible (usually less than 1/4 inch exposed length) to reduce EMI noise risk. Still wanna do it? ok-for starters, you'll need a dual 10k ohm to 50k ohm pot(if your old amp is like most and has a 500mv input sensitivity, go with a 20k ohm pot if u can find)...use the circuit board type if you're gonna drill a hole in your amp case and mount it to show like a newfangled amp, or go with a larger, volume-control size dual pot if u insist on having it up front. There is the cheaper single turn type, and there's the 10 or 20 turn precision type that I much prefer, although they are about $20-$30.00. From here, just tap into the rca cables somewhere , soldering one side of the signal wire (say head unit side) to the leftmost contact if th pot handl is facing u and th contacts r up; connect th amp side to th middl contact-leave th right one open, I don't like to shunt any signal to ground, no-no. Connect both sides of th shielded part together. Repeat for other channel, mount pot,and u have take-off. Or, u could just buy a new amp...
For more on gain settings, see my response in forum topic titled "amplifier gain settings"...also, if u do not have ENOUGH gain from your head unit to saturate your amp, I can help there too, but it gets a bit complicated and I gotta charge$(jst kiddng)
If your not up to doing it youself - car audio install places can do it fairly cheap - you should be able to get it done for about $35
I hold firm on the deposit in all situations 😎
  • Locked
I dont see a Username and date on any of these pics that the FOR SALE Rules Should Apply. Are these pics off Ebay?? Place those with the pics so...
Voltage for the signal? What does that mean? Electricity isn't measured in purpose. Gain is a characteristic of a circuit. You aren't adjusting...
20
6K
You can get close with tones, but music signal is all OVER the place in both frequencies and voltages. Like, if you listen to rap, the bass line...
833
Guest
    Jun 1, 2024
    May 31, 2024
