Here's something I hope you can will all use to your benefits. As you may or may not have noticed, most equipment dies for one simple reason : Most people push their equipment beyond its limits. Whether its the amplifier or subwoofer or speakers, clipping is the number one cause of failure that I see. To prevent clipping, I've made this tutorial (Well, JL Audio did, but I've been doing this for years before they put it on their site).
Okay, before I post the links, there's just one problem that I have with the following guide. It says to use 75% of max volume. I don't agree with this at all because, with some head units, you can crank it up to full without distortion and with others, it may only be 60% ... To set your gains, use the MAX settings you'd NORMALLY use ... If the loudest you listen to your music at on a regular basis is 22/35 with bass @ +3 and treble @ 0 with MX on, by all means use those settings...
