******geo Metro Wall Build ******
This is with just the stock alt on.
This is with both alts on.
u dont like it?
what if u take that off and stretch some fleece and glass it so it looks more like it was supposed to be there (curvy) rather than a flat piece of wood
u dont like it?
i like it, that's why i said Decent.
going to put some type of raised lettering there //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Ok then 11 cubes will be fine. Keep in mind the f/s of those woofers is about 28 hz, so you if you tune really high above that, the woofers can...
What would you recommend using for the roof then ? Should I do just the bpillar or the whole roof ?
901
If you order directly from taramps in brazil you can get a smart 3k for $259 shipped...
These are the tweeters in going to use in my truck. Beefy little guys just going by weight. Probably not the best for a car audio setup, but I'll...
63
8K
JBLCAMRY
KCB
JBLCAMRY
239, Florida
BoomTaco64
    May 24, 2024
    May 23, 2024
