Give me the **** truth about RCA's
EpicMango
Colorado
I've spent all day looking at RCA cables and I'm hearing everything mixed around about them. Some say their mono price RCA's are better than their Stinger series, some say KnuKonceptz Krystal is okay, while others say there is a big difference between that and their eKs line and some are saying the eKs line is just something to behold..what is true?
I'm really not getting a definitive answer here. It would be nice if there was some real world tests to all these claims not only for just me but for the future people that will have this same **** question.
What the hell makes an RCA sound better than other ones? Does it really matter? Is it audible? Or are we more concerned with shielding rather than SQ?
I have Knu and couldn't be happier.
Any good brand will be fine. Even if you spent a few 1000 on some, there's no audioable difference.
Your getting the runaround because people don't know any better or they think 1 brand tops them all.
No one has ever heard the difference in cables in a blind test. Get something of decent quality and focus on things that can make a difference.
You don't have to spend a ton of money on rcas. That being said, you don't want the cheapest pair out there. As long as they have pretty good shielding you'll be fine. You'll never hear the difference between monoprice and stinger or any other expensive brand. You are however paying for quality and longevity so always factor that in.
No make or model number on it? Do you have an exact picture of the rear and all its glory?
8
809
Use two sets of RCAs. One set for the Front channels and the other for Sub Output and into Rear Input on the amp. Turn off the Rear Filter on the...
5
827
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
703
He'll be fine with any 4 ohm speakers, tuned properly. The focals are rated for 100 watts nominal and with the passive crossovers and power to...
6
818
Try this other test; get a 3.5mm headphone repair cable and connect it to the LC7i input. Connect that to your phone and measure. This will tell...
11
923
EpicMango
EpicMango
Colorado
jordon
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
