Good 300 Watt RMS 12" Subwoofer?
  • 5
This Is a NIB amplifier, one of two that I was to use. Decided to go class A/B on the front mids and tweets and just purchased a Helix B FOUR...
Good thing its under warranty and that you have contacted A.Control about the issue so it has been documented. It will help speed up the return...
He wants to strap the amps to double the output to one sub. Some amps allow you to "couple" them. This allows you to wire up the one sub powered...
You can wire those subs up @8 ohms if they are both SVC4 ohm subs,and that amp will run fine after being tuned properly...
Nutz
Team Nutz, Pgh PA
Nutz
Pittsburgh, PA
Nutz
    May 20, 2024
    May 20, 2024
