Ground location? (1st timer)
  • 6
nexbico
USA
I have a 92 Honda accord sedan
In the trunk, there are a couple of rubber plugs
1 really grabs my attention.
I was just wondering if my ground location is a good or bad idea
Rubber plug on right side of trunk
Rubber plug removed
Inside the hole
The hole extends to the bottom frame
Frame from the bottom
My idea was to cover the hole with a circular metal on top. Run a bolt through the middle down to the hole in the frame. Secure it with a bolt nut on the bottom of the frame.
Good or bad? and yes, i know it is dirty :p
This is for an Amp's ground
That should work just fine. Make sure you use sandpaper to remove any paint, needs to be bare metal.
As much of a good job you've done with the extremely detailed pics on your post I'm sure you'll do a good job. I could recommend using a small screw with a washer and nut, this way you'll be secure
Hmm, I'll give 2 thumbs up for that advice. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Yah, we both know that I got that magnificent advice from you. And YES its very usefull. I hope you don't mind me passing it on. Sharing is caring:D:veryhapp:
Never seen a screw with a washer & nut....now a bolt on the other hand....//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Thx for the input everyone. Hopefully I'll have finsh pics in like.... 4 err.... or 8 months //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
I would recommend using a washer on both ends of the bolt to give a better contact area.
After you are done making the connection, be sure to either spray paint the exterior or put some silicone around it... Since it is exposed completely to the elements.
Good job, that was just a test and you passed. I make mistakes like that at random, just to see if people are paying attention. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif:laugh:
P.S. Thanks for the respectful correction
Another question
Will it matter if I use copper flashing in stack(layers) as the plate, and solder them together?
Or it doesn't matter what type of metal I will use as a plate?
Thx
I agree…not a very good install. Hopefully you didn’t pay much (hopefully it was free). Get your DMM (or find someone who has one) and find a...
Single ground. If there is one thing car audio proves it's that the saying "Ground is ground the world round" is complete BS.
290
I'm guessing that's what it is. There's not a lot of room back there.
It’s nice having a test bench. That one is nice and clean! I don’t have pics of mine but mine is built all out of wood with carpet top and all...
16
In the following order: DOWN4SOUND JFX653S - 6.5 INCH 3 WAY CAR AUDIO SPEAKERS - I did a good listening of these and was pretty impressed. It...
20
nexbico
nexbico
USA
nexbico
    May 31, 2024
    May 24, 2024
