Having trouble picking 10’s
  • 4
Rob93
Hey all, I’m looking for 2 10’s for a new build. I figured I should ask here because I be been looking for days can’t seem to find exactly what I’m looking for and maybe someone will have a suggestion.
current setup:
2.6^ custom ported box @28Hz
12” skar vxf 4ohm DVC
Orion 2500.1 birth sheet @2985rms
I don’t have any more useable space so I will be rebuilding my current box just with 2 10’s one on each side. I was considering sundown SA 10 V2 (I’ve read they can handle 1500) but that leaves a lot of wasted rms in my headspace. Does anyone know of any reputable CEA certified subwoofers that have a 12-1400 rms rating? Preferably that won’t break the bank.. less than $400 each is semi-realistic If space is an issue I have already considered going downfiring inverted to gain a pinch.
ty for read
23989
With that kind of vehicle you should try subs up port to the side. I'd look at 4 8s if you can't fit 10s across the top.
Cea certification only applies to amplifers at a 4 ohm load, < 1% thd and 1khz. Its not a very useful rating at all and does not apply to any sort of speaker.
I totally get your guys recommendations, there are reasons it is set up the way it is though. I have 3 kids too, lol. Good to know about CEA only really meaning something with amps. I did consider 4 8’s as well but what I was looking at would have been sundown I believe and costed around 800 before tax for just subs and only drop me at 2k rms total. I know the design could be better but it is still an absolute beast nonetheless.
I will consider 8’s in general.
If you guys have any recommendations on those as well they are welcome. I do still think aesthetically a 10 on each side would look great and hit harder for multiple reasons.
23990
I've seen a 4 10 setup in a trunk car with opposed side firing subs and a rear firing port but I'm not sure that combo would work in all vehicles. You definitely do not want opposed firing ports and subs, that's a recipe for cancellation.
Seems kind of stupid to prevent helping others with advice on equipment from Amazon, doubt that Amazon is preventing this either. Pain in the arse!
14
977
I'm not a big fan of Brand X personally. My car idles at 500rpm and my Autotech didn't turn on until 650. I sent it back and he redid it to turn...
878
https://www.caraudio.com/threads/all-bnib-focal-fdp-4-600-ds18-exl-p2500-1-sundown-audio-sfb-1000-4d-350x4-4ohms.614462/ :)
18
I would Double check the LC2I settings also and make sure all wiring is secure and not loose as well.
Update I have been playing with the silver flutes and just can not get what I want out of them. I spoke to stereo integrity today and ordered a...
Rob93
Rob93
Philadelphia, PA
SlugButter
maylar
    Jun 2, 2024
    Jun 1, 2024
