Head unit help
  • 5
ur gonna have some sockets(bolts) to remmove, i dont no what size off hand tho.Also ull have clips to remove and some vents.
ull have one bolt above gauges. Then 2 understearing wheel in the lower part of dash Ur gon have 2 more near the bottom of the lower dash, ull have to get on the floor to remove them. Once those are out, the lower dash will come off. u will reveal 2 more under the lower dash that u jsut removed. then u should beable to pull the upper dash apart.but before that will come off, Ull have som clips to remove on the right hand side have ur strearing wiheel where the lights control is and ac vent to unclip. THen on the other side u will have all the ac/heat/4wd and maybe some other clips to undo. Ull also have 2 more air vents to unclip. Then pull the whole dash apart, but make sure all the clips are undone cuz u dont wanna break any of those. Then once thats off ur gonna have 4 bolts to remove that secure the stock radio in. Then u should be good. Install ur dash kit and cage and then slide in ur radio. If u have any question pm. i have a 2000 gmc jimmy and they are identical.
There is a 7mm bolt where your guages are take it out. there is 2 to the left and right under your steering wheel and 2 more on left and right at the very bottom of the same piece. Pull that one a little loose and then you can pull the piece with your guages out and undo those wires hooked up and now you can get the hu out.
https://youtube.com/@SaabUnleashed?si=-8qdxpYY0yGzrMsL Here you go. This guy does android head unit reviews. His reviews are how I found my...
7
Yes, the power wires' colors don't match from the dash to the new harness. However, I tested them and the wire I'm treating as the constant 12v is...
9
There's definitely quite a few that can give a better answer, but IMO, it's (1) 8" sub. It's supposed to be quicky and jabby, not a power...
7
Hi Bud. I will be honest with you on this. All these units from Aliexpress dont last. they are junk. I have had one in the older honda civic 8th...
22
5K
Im sure you could find a great deal on here as well for your mids and highs. Just another great speaker to be considered. Audio Frog may be...
6
Davecubs14
Davecubs14
Madison, AL
1rockford1
maylar
    Jun 2, 2024
Doxquzme
    Jun 1, 2024
