Headunit not turning on
  • 2
Bcmonks
A week ago my front speakers stopped playing music and my amplifier was staying on when I turned off my car, I decided that the problem was most likely my amplifier so I bought a new one. Today my amplifier came in the mail so I hooked it up and noticed that my front left speaker sounded muffled, so I turned off my car and checked my connections. When I turned on my car again, my remote wire, which is located on the fuse that corresponds to the radio in my car, arced. Now my head unit does not turn on, while my amplifier does. I visually checked the fuse in the head unit but it didn't seem to have anything wrong with it, although I didn't check it with a multimeter.
TL;DR: Installed new amp, remote wire arced in fuse box, Headunit doesn't turn on.
Any help would be greatly appreciated.
It could be a multiple of things it could be that your amp will always be on if thats the case you want to check your wiring for your amp if your amp doesnt always stay on or turn on then it could be an issue with the radio so check the radio wire harness to see if you have power memory and a ground
what ^ said. amp gain setting info, test tones are at the very bottom...
553
Twist both grounds together. Good call on checking power with a multimeter. I assume you have pulled out and re-inserted the fuses, so as a quick...
It's a Volvo factory amp, so there's a custom wire harness between the head and amp.
6
On another note, if you're competing in SPL, you might want to check around at what the best crossover point is. These two drivers (your 6.5s and...
8
Bcmonks
Bcmonks
United States
meekgj
maylar
    Jun 2, 2024
Doxquzme
    Jun 1, 2024
