Help 95 Crown Vic Won't crank when gets hot!
I think it's your starter, the starter motor is brunt out.
The heat from the manifolds/headers will kill them fast, if you don't have a heat shield, replace the whole starter and i bet it solves your problem.
I'm still baffled as to why she'd come here to ask said question. So guys, give this stranger money so she can put diapers on her kid.
162
452
427
Katy Fincannon
Katy Fincannon
Cleveland, Georgia, United States
akheathen
    Jun 1, 2024
    May 31, 2024
