HELP for my son's Alpine Head-Unit - blackout mode
Which he says is labled between Mute and Source... So hold down either one and see what happens.
Is this a used unit?
I think linda would be a she //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif.
the manual says to press and hold blackout for 2 seconds
worked for me
To original poster...go to alpine1.com then go to support....when it bring you to that screen it will give you the option to "continue without login"....click that go the manuals the acrhived cd players and then to your model //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I would just post a direct link but it wont let me //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
Yeah, I appreciate the suggestion. Got the manual, but the darn thing says to press the BLACKOUT button...the problem is, is that there ISN'T a blackout button. It's between the Mute and Source buttons. Pressing both or a combination for over 5 seconds doesn't do anything but mute the radio...this is frustrating.
Also, I bought a used unit on eBay for only $9.99...can't get it out of blackout mode either.
LAWL...sorry bout your luck.
NG
there is no button directly above or below where it says blackout? Could always call alpine in tomorrow if necessary.
img.asp
in case it helps you boys figure out the problem. Thank me later Linda
EDIT: Linda, WHat about that key under the word Demo.... what if you press that and then the Mute button afterwards
img.asp
Yeah, that's the F button, which I assume is function. However, that's not working either. If you look at the picture you can see that the blackout word is above the mute button. So, I've been trying every combination....ARGH!
I DO APPRECIATE EVERYONE'S HELP...KEEP IT COMING IF YOU THINK OF ANYTHING!
Maybe some pictures of youself would help us with this issue...
Just a thought //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Well, I'm 40, but I've still got it. BUT, I save it all for my hubby. sorry guys....
OK, I've thoroughly been through the manual online at Alpine. I've printed them and went out and sat in the car and did the instructions as they indicated. Both of the faceplates won't come out of blackout mode. I'm stumped....HELP PLEASE!
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
138
Turn the volume completely down and operate ot normally. This is to see if it is the built in amplifier that is shutting down. If the radio does...
That would be a function of the harness, not the HU, I think. Have you looked into a Maestro or iData interface? i would check with crutchfield...
12
442
Dammned good speakers. Just pass up the CL series,and you will be pleased with CDT speakers. I still enjoy all mine. Polk MM series and Infinity...
4
420
#1bugsbunnyfan
#1bugsbunnyfan
Raleigh, NC
#1bugsbunnyfan
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
