Help for someone new?
Hey welcome to the board.
1.) most people just ditch the rear fill and upgrade the fronts to a nice component set.
2.) A good price for a sub depends on what your looking for i.e 10",12",15" as far as placement a box in the trunk is most typical
3.) Yes to power the spakers properly youll need an amp or even two. one for the fronts and a sub amp. As far as wattage goes just go by the RMS power rating of the speakers your going to power with the amp.
A price range at this point is nearly impossible but just as an idea:
front components- ~$100
component amp- ~$100
subs- varies waaay to much a crappy 10 for $50 or a nice 15" for upwards of $250
and sub amp- again depending on setup but ~$200-300
oh and wiring-~$40-$50
hope this helps, you ll get a more accurate price estimate once you figure out what setup your goin with.
I cant afford a 1000$ system but I'd say im willing to spend around 250-350$.. if i need more which i probably think i will then i could get some more.
Edit: oh thanks copper... i didnt realize i needed maybe more than one amp.. so im guessing i would need more money then what i said before?
Pioneer subs are good budget subs, and for amps hifonics are good budget amps.I would say get 2 12s and an amp for 350 and deal with the speakers in you car until you have enough money saved up to buy a good component set and an amp
could you maybe tell me a good set to buy?
I personally always recommending buying components and an amp b4 you put any money into bass. Unless you really like 75% of the noise in your car to be bass with the other 25% distorted paper cones.
I think you should either get new components and an amp, OR a new sub and an amp.
If you get a decent head unit, you can keep the stock speakers and get a new sub + amp. This will sound pretty good.
Then, when you have some $, you can add some 6.5 components for the front along with a good 4 channel amp putting out some good power.
If you want a good deal on some subs, I am selling a pair of phoenix gold Xenon 12" subs for $160. I posted a thread in the FS section.
Hello!I'm in France and I can't register on Hifiengine for unknown reasons and i need to download the service manuals for Blaupunkt Baden Baden...
Still not convinced? https://gpcaraudio.com/15-dual-high-output-glue-it-screw-it-sub-enclosure/ You can order the box glue and screw kit with...
15
78
I would tend to blame the amp more than tbe sub if all wiring checks out. Skar is known to be on the finicky side when abused (not enough power...
126
xNaStYx
yo
xNaStYx
lolz
xNaStYx
audiobaun
    May 19, 2024
    May 19, 2024
