Help from Down Under
  • Thread starter Unregistered
  • Start date
  • Replies 1
  • Views 806
  • 1
U
Unregistered
Guest
Hi guys, my boyfriend wants to be a head unit, Sony one with mp3 cd player, and I want to know can we put them in Aussie cars. Is the wiring the same of different? I dont want to order one from the US to find its not compatible.
Any help will be appreciated
Thanks!
aussie car as in it was made there? if so, it is a 12 volt system right? if so (should be) then the sony will work. wire colors will be different (probably) then u.s. cars, so it might be hard to explain how to wire it. if you r going to diy then get a volt/ohm meter and a install kit(try crutchfield.com or a local installer) and just follow the directions that come with the sony. it will cost you but the easiest way is take it to a local audio shop and let them install it.
Yes, the power wires' colors don't match from the dash to the new harness. However, I tested them and the wire I'm treating as the constant 12v is...
9
Dammned good speakers. Just pass up the CL series,and you will be pleased with CDT speakers. I still enjoy all mine. Polk MM series and Infinity...
4
100
I would tend to blame the amp more than tbe sub if all wiring checks out. Skar is known to be on the finicky side when abused (not enough power...
9
140
The cutting it off part is what I'm confused about now. The speakers in my car have two wires coming off of them but I would only have one wire on...
243
Guest
mrray13
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
