Help installing amp in new 2013 accord
  • 2
Jaxxx
Usa
Looking to run an amp in the rink but can't figure out where to run the power wire through the firewall and where to hook up the remote wire.
I didn't see anything on the firewall from looking with a flashlight and it has a touch screen radio which is not like any other aftermarket radios I've worked with years ago.
There is a easy way through the firewall it is located to the left of the driver foot rest you will see three grommets remove one and feed wire thru. From there if you open the hood and look to the location of your wipers on the drivers side there is a piece of rubber that can be lifted up which gives you access to pull the wire thru and into the engine compartment. you can use a hanger to pull wire through.
Let me clarify I meant remote wire on my original post....... I will look through the footrest tonight for the power wire.
I'm not sure that's why I ran the dsp first so I could level it all out. Some do have the factory mine didnt
I believe that the LC2i has a fixed subsonic filter at 33hz, that will affect the low end too. THe LCi2 pro has a set filter at 22 hz, better...
24
219
Im pretty curious as well.I am wondering what all took place for the supply for the demand?
649
Jaxxx
Jaxxx
Usa
Jaxxx
    May 18, 2024
    May 18, 2024
