Help me choose my setup!
If the convenience of having someone do it for you is worth that, then you should be happy. It really depends on the quality of work and how much you need the convenience to tell if $2500 is a rip off or appropriate. I tell people all the time that it may not be worth it for you to do things yourself. If your hourly rate is $$$$$/hr+ and something saves you your times worth in money it's not a bad purchase.
If you're bothered by not having OBDII readings, just buy a $20 bluetooth module off of amazon or ebay and use it with torque pro on your phone. If you REALLY want the functions you can sell your headunit and buy the upgrade.
It was actually very helpful. I have 5 kids so finding time to run the all the wires and installing is time consuming for me lol.
As for quality of work, they did the install right. Fed all the wires through the firewall etc everything is hidden and clean. Only real complaint I have about the install is the idatalink obd module wasn't offered. I have a Bluetooth reader that hooks to my phone but being able to have it all at my finger tips through my headunit would have been nice. Also they did a really shitty job vaccuming the tips of the wires that were stripped. Had to clean that up myself. Other then that I am happy with the work they did and the sound system I have.. The JBL 10 inch Stadium subwoofer does a decent job but doesn't compare to my old set up with 2 12s obviously but that was a sacrifice I was willing to make to save space from the get go.
Thats pretty typical of most shops. But with that being said, if you're paying a premium price, I'd only expect to find little pieces of wire in the most obscure crevices. Not out in the open like you're talking about. I expect that they charged you at least $80/hr
It wouldn't hurt to ask if they'd offer you some sort of upgrade only cost considering you'd like that functionality.
Well I thought about asking this as when I went in there originally I had asked for it to be installed from the beginning but apparently the installers never heard....
This would be a decent amplifier to run on what you have. I would spend a little more and get the 460.4 if you can swing the extra funds. Ive...
4
Sub should be in the cargo area for best results. I'm skeptical about those unknown brand Chinese head units myself and would stick to known...
I am upgrading standard door & dash speakers in a VW T5 camper (2005) using a plug and play upgrade bundle, continuing with the two-way setup...
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
157
Turn the volume completely down and operate ot normally. This is to see if it is the built in amplifier that is shutting down. If the radio does...
Keith Longpre
CarAudio.com Newbie
Keith Longpre
Keith Longpre
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
