Help me design my box :)
Mdumaw
I tried to design a box on this program but... im not sure if these dimensions will work very well at all.
it should be about 3.5ft^3 total minus the ports and 5/8 wall divideing the subs.
I was planning on putting to cvr 12's in it.
i've built a couple boxes before, but this is my box so i want it to be good and figured i should check with the pros.
its going in my prizm and i have about 16 1/2 between the speaker magnets and the floor of the trunk and 42" inch limit on width so im shooting for bout 15"X38-40"X x"
Thanks guys!!//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
View attachment 26524501View attachment 26524502View attachment 26524503View attachment 26524504
^^^ i agree... you've got the front baffles on that box slanting in two different directions. that is going to be insanely difficult to cut perfectly
ya... idk i just liked the look of it. figured cutting it out would be a royal pain. but i liked it prolly end up making the front flat //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
so what internal dimensions should i look at for the port vs. box volume?
I've used that driver and the ported box is closer to about 2 cubes. We did 1 in a stuffed/sealed 1-1.25 cubic foot box, stuffed with 1 lb of...
819
People didn't like ported boxes because the port noise and needing a bigger box. Therefore, instead of 1-sub in a ported, they would go with...
30
In the meantime you could stuff that port hole with a blanket or some pillows and it would probably sound better, if you want to listen to some...
Buddy of mine somehow managed to get small MDF boxes set into the rear doors on his previous truck, think it was an F-150. I can't remember...
Mdumaw
Mdumaw
Newport, WA
Mdumaw
    May 31, 2024
    May 24, 2024
