help! rear speakers fading out between r and l sides..
  • 1
luke32303
I have a 4 channel amp run from an electronic crossover and recently the rear speakers have been acting up. Either one or the other will work, usually not both. If I turn up the volume pretty high, the one that isn't working will sputter and come on for a short time, then it usually goes back out. Sometimes the right rear will make a popping sound. The 2 front components work fine all the time. Anyone have any idea what is going on?
870
182
459
446
luke32303
luke32303
Jacksonville.FL
luke32303
maylar
    Jun 2, 2024
    Jun 1, 2024
