Help w/ Kenwood KDCMP342U & CA-C1AUX to Zune
  • 1
JSK
Hi guys.
I recently picked up a KDC-MP342U, also a CA-C1AUX to use the rear output for a RCA-to-headphone jack cable to my Zune. (Didn't want to use the front adapter as every time I take off the face i need to then unplug it)
It is all installed fine, everything plays, except the Zune. I set the source to AUX, turn on and play the Zune, volume up on both items and I get nothing and I don't know why. I've verified the connections, everything is plugged in,
Is there something I am missing in the menus to switch to the Rear-AUX? Is there something else I may have missed?
Any help getting my Zune working with this deck/adapter combo would be appreciated. The Kenwood manual is about as straightforward as a mountain road and there really isn't any specifics regarding the rear-AUX in.
Honestly I don't think it would be hard for them to make it where you use android auto AND your own music source. They made it able to do so...
5
575
I have a seat Leon 2010 1.6tdi it’s fitted with a seat unit that won’t load sd card internal error so bought the above stereo to upgrade and a...
I would call Kenwood Tech support. Im sure they will try to help you
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
167
Turn the volume completely down and operate ot normally. This is to see if it is the built in amplifier that is shutting down. If the radio does...
JSK
JSK
Michigan
JSK
maylar
    Jun 2, 2024
Doxquzme
    Jun 1, 2024
