Help with alarm system
Hello all. New to this forum and need some help. My car has an DEI Rattler model 300 installed by the previous owner. My wife left the lights on and killed the battery:mad: . After charging up the battery and putting it back in the car the car would not start until I removed the fuse going to the alarm system. After I got the car running I played with the alarm system and got it where the car would start with the fuse in (I armed and disarmed the system with the remote). Now when I arm the system the lights blink but the alarm no longer chirps. Not sure if the alarm was working correctly I set the alarm and opened the door and got in the car to see if it would go off. I could here the control unit under the dash clicking but the alarm did not sound.//content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif I think that I may need to reprogram the system but do not know how and do not have the instruction manual that came with the system. Can anyone here help me?
Thanks in advance.//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
It sounds like you have it in Valet mode. On most DEI alarms, you can enable/disable valet mode thru the following procedure:
Open the door
Insert the key
Turn the key to the "run" position
Turn the key off
Press and release the valet switch (black button)
If the LED light comes on and stays on, the alarm is in valet mode. If it goes off, it's out of valet mode.
205
Im pretty curious as well.I am wondering what all took place for the supply for the demand?
616
402
Agreed with this here. Since you have the unit pulled out of the car/dash...test it at your car battery directly for operation. very simple to do...
377
midknightryder
midknightryder
Rockmart, ga
Eugenics
    May 18, 2024
    May 18, 2024
