help with connection on a 8" loudspeaker with 2 channel or 4 channel amp
  • 1
112
Sounds like you already have a plan. Hook it up and let us know how it worked. Good luck.
433
406
TeamExplosion
TeamExplosion
Miami,FL
TeamExplosion
    May 31, 2024
    May 24, 2024
