Help with Electrical Upgrades
  • 2
Fi-brations
Memphis, TN
I need some help with my new build. This is the most power I'll have ever ran, and I'm not exactly sure what all I need.
My amps are an Audiosystem X-Ion 160.4 = 640w
And a Taramps DSP3k = around 3kw. So I have roughly 3640w being drawn, but I only do music so should be a little lower I guess...
For the alternator, I'm looking at this Mechman 270a alt G Series 270 amp 6 phase Nissan / Infinity 3.5L alternator - Mechman Alternators
How many batteries do I need?
As of now I have a used Deka Intimadator 105ah (not installed) and my regular, almost brand new wet cell (installed).
Do I really need to buy two large batteries of the same type and age and a smaller agm for the front? Or would I be ok to use the deka with another battery of similar size, and isolate* it from the wet cell up front (*which idk how to do yet).
If I end up getting three new batts(2 in back, 1 smaller up front, all agm) do I need or want to isolate the smaller one? That way I can have two for the amps and the small one for normal car electrical?
I'd also like to know exactly where all I need fuses and how many runs of + & -
I have a Knukonceptz fused distro with 3 fuse holders as well as one Knu inline fuse that has a 250A rn from previous build, I'm assuming I'll need a 300A now for the taramps 3k, right? The audiosystems amp has 3 x 40a on board fuses already.
Do I need to run negative to negative on the batteries or just have multiple grounds?
Thank you.
When I got my mechman alt, I just bought multiple belts of various lengths from Napa auto parts, the clerk said i could return it if it didnt fit. (which I did)
I would recommend getting a bank of maxwell caps in addition, the maxwell caps gave me the best noticeable help with voltage stabilization.(vs having more batteries) Without caps my voltage would drop very quickly.
I always heard 100ah to a 1000 watts was the recommendation for batteries to power draw.
I would recommend 2 runs of + and - (each) of 0 gauge to the back batteries.
Sounds good, my dad's a used car dealer, so he would know the napa guy or wherever as well.
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
142
Turn the volume completely down and operate ot normally. This is to see if it is the built in amplifier that is shutting down. If the radio does...
Fi-brations
Fi-brations
Memphis, TN
Fi-brations
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
