help with focal 3way comp
  • 2
breezes
Hey dudes i have a problem, i have a focal 3 way polyglass set of comp, i have a 99 ford f-150, i mounted the 6.5 midbass in the stock 6by8 spot and the tweet above it but i am having problems with the mounting of the 4 inch mid, help !!!!!!!!!!!!!!!!!!!!!!!!!!! any will be thanked,
Kickpanels. Build (or buy, and then reinforce) kickpanels to mount them in. You'll want the pathlengths to be as close to even as possible, and you'll want to be able to aim them......kickpanels are the best way to acheive this.
thanks ,but i already have a set of kicks and they have a 7 inch sub in them for some bass up front, the 4 has to go in the door as close as i can get it to the 6.5 and the tweet, need more help!!!!!!!!!!!!!!!!11
Hey man......I can only reply so fast. I mean, I am supposed to be trying to get some work done here //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
What headunit do you have, and do you have any pics of the door (or atleast pics from the net of what your door looks like)?? Also, is there anywhere else the subs can, like build a center console for them??
Cause, if you aren't willing to relocated the subs from the kicks, then if you had time alignment you may be able to go somewhere like mid-way up the door, and build so door pods so that you can aim them. But the kicks would IMO be the best option. So, answer my questions above and we'll see where it takes us //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Yes, one shop is absolute best and last time they let me return it even when i mounted it on the car and tried it :)
162
451
427
breezes
breezes
MESQUITE,TX
squeak9798
    Jun 1, 2024
    May 31, 2024
