Help with Jensen cdh1000 installation in 94 mustang gt conv.
  • Thread starter <kmccalli18>
  • Start date
  • Replies 1
  • Views 2K
  • 1
<kmccalli18>
Guest
I am going to install a jensen cdh1000 head unit in my 94 mustang gt. Do I have to remove the dash, or just insert the proper tools into the four holes of the factory unit and pull it out???
Also, will I need the harness or not???
you can get the tool you need at walmart for like 3 bucks, or if you are careful and have 4 allan wrenches that fit in the holes you can use them. If you buy the tool it is shaped like a u and is just a tunning fork looking thing
I have installed a alpine sub and amp, using a line output converter it all works but the bass stays steady and does not change with the volume...
103
244
Guest
gregj9
audiobaun
    May 19, 2024
    May 19, 2024
