Help with setting up subwoofer
  • 2
Wez potter
CarAudio.com Newbie
Essex
Hi have had an aftermarket stereo fitted (jvc) and when fitted had a wire converter put in for all speakers to work but is plugged into RCA port but am looking to wire up a subwoofer how do I convert rca port to run speakers and subwoofer at the same time any advice would be great thank you šŸ˜Š
You need to explain a little better. A wire converter is plugged into an RCA port on your head unit, or a converter was connected to the amplifier in the head unit to give you RCA (line-level) output?
You cannot run speakers direct from an RCA jack on a head unit. If that is what you have, you will need an amplifier.
What JVC head are you running?
Cool, thanks guys. This is what I was thinking but wasnā€™t sure. Iā€™ll go out and retune tomorrow in some daylight.
4
Dammned good speakers. Just pass up the CL series,and you will be pleased with CDT speakers. I still enjoy all mine. Polk MM series and Infinity...
4
79
I would tend to blame the amp more than tbe sub if all wiring checks out. Skar is known to be on the finicky side when abused (not enough power...
9
127
Wez potter
CarAudio.com Newbie
Wez potter
Essex
RobGMN
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
