Hifonics Brz 2100.1d
  • 4
serjr711.
Antioch,Ca
Item(s) for Sale: ^^^^
Brutus Series Monoblock Class D Car Amplifier
RMS Power Rating (@ 14.4V):
4 ohms: 700 watts x 1 chan.
2 ohms: 1400 watts x 1 chan.
1 ohm: 2100 watts x 1 chan.
MOSFET power supply
Wired HFR-3 remote bass level control included
LED power (green) and protect (red) indicators
Variable Bass Boost (0 to +10 dB bass boost at 45 Hz)
Mono channel operation
Preamp RCA outputs to daisy chain multiple amps
4-Way System Protection circuitry (thermal, overload, speaker short and DC protect)
Heavy duty aluminum alloy finned heatsink for maximum heat dissipation
Silver-plated unbalanced RCA level inputs
Silver-plated molded screw terminals
Input sensitivity:
Input Level (Unbalanced): 0.2V-9V
Input Level (Balanced): 0.04V-18V
Variable low-pass filter (35-250 Hz, 24 dB/octave)
Subsonic filter (15-35 Hz, 24 dB/octave)
Phase Shift: 0-180°
Damping factor: >290
Frequency response: 35-250 Hz
CEA-2006 compliant amplifier
Dimensions: 19-2/3"L x 9-1/4"W x 2-7/16"H
Super condition with some small scratches, nothing major,
210.00 shipped
IMAG1222 by cartman38, on Flickr
IMAG1223 by cartman38, on Flickr
IMAG1224 by cartman38, on Flickr
IMAG1225 by cartman38, on Flickr
Yep, at the amplifiers. I get the same 14.7 volt reading when they cutoff too.
Pull it and test it at the battery post. Simple Power up test to verify if it powers up fine out of protect mode. if it does then Id be checking...
I have a Gemeni VII, Heucules VII, Pluto VII, and a Vulcan VII left out of a massive slew of VII and VIII series. They still work Excellent...
  • Locked
COMPLETED Hifonics Plato III
Yes, they are painted. The cover is very easy to take off and repaint to whatever color of choice to match the install.
serjr711.
serjr711.
Antioch,Ca
serjr711.
just call me KeV
    Jun 2, 2024
just call me KeV
    Jun 2, 2024
