Hifonics Colossus Question
bigred78797
Audiobahn Junkie
Ok quick question... As you all know im wanting to get a colossus For my subs... If i can save up enough money after the amps to get CSX's ill get them. But anyway here is my question... Im pretty sure they are but are the Colossus 1 ohm stable? if so about how much do they put out at that load semi cleanly?
The colossus, is 2 ohm stable, I personally wouldn't run it at 1 ohm daily although with box rise it may end up being fine. And if your running it to 2 subs you can run it stereo and do each channel at 1 ohm, or .7 fine. But, if I were you I would wait and get the CSX's first if your talking about those 15s for 250, and get the colossus later, it has been discontinued infact for the colossus II, I say wait for the amp and get the CSX and get a colossus II when they are more commercially available which should be very soon, or even get an autotek MM4000.1.
if your wanting anything through maxxsonocs.. let me know.. i may be able to get you some better prices....
Are you thinking of running the Colossus 1 ohm bridged? Can't say for the older model, but I've got the newer model (silver/black ribs) I'm pushing a single 12" with it, for daily use, amp actually got hotter when it ran at 2 ohms than it does at 1 ohm. Also, it doesn't clip anywhere near as much as it did at 2 ohms. Just my 2 cents! :]
Yep, at the amplifiers. I get the same 14.7 volt reading when they cutoff too.
12
Pull it and test it at the battery post. Simple Power up test to verify if it powers up fine out of protect mode. if it does then Id be checking...
I have a Gemeni VII, Heucules VII, Pluto VII, and a Vulcan VII left out of a massive slew of VII and VIII series. They still work Excellent...
5
3K
  • Locked
COMPLETED Hifonics Plato III
Yes, they are painted. The cover is very easy to take off and repaint to whatever color of choice to match the install.
LOL - mine was a higher end model too - iirc deh-9300. Low mileage too, it was sitting around for year collecting dust.
7
290
bigred78797
Audiobahn Junkie
bigred78797
Fort Meade, MD
Schism1000
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
