Hifonics zxx 2400.1 stuck in protect mode. Help plz
Cab anyone tell me how to get this amp out of protect mode please?
Did you test it with no speakers? When an amp is in protect mode, it usually means something inside failed. On occasion it is something as simple as wire strands shorting between terminals. Do a visual inspection of it all (including interior) to see if you find something obvious.
Pull it and test it at the battery post. Simple Power up test to verify if it powers up fine out of protect mode. if it does then Id be checking Ohm load of subs and all wire secured, from supply wiring to ground wiring and connections, damaged inline fuse as well.
Yep, at the amplifiers. I get the same 14.7 volt reading when they cutoff too.
I have a Gemeni VII, Heucules VII, Pluto VII, and a Vulcan VII left out of a massive slew of VII and VIII series. They still work Excellent...
  • Locked
COMPLETED Hifonics Plato III
Yes, they are painted. The cover is very easy to take off and repaint to whatever color of choice to match the install.
Ok, i will go on this option. Thanks a lot bro for the help, i really appreciate again, Cheers
753
RFgangIE
RFgangIE
GRAND TERRACE, CA
audiobaun
    May 12, 2024
Brendon Jenness
    May 11, 2024
