How do I bypass factory amp?
  • 4
I have a 2000 monte carlo ss and my speakers are getting no sound and every once in a while fade in and out. I have a aftermarket kenwood deck, Polk audio front speakers and stock rear speakers. Haven't had a problem before now. I have come to the conclusion that my factory amp is going bad. After reading about this I think I will have to "bypass" the amp... How exactly would I do this. I'm a little confused as to what it means and how to do it. Someone please help me out!
You can either replace the factory amp with an aftermarket amp, or you can bypass the factory amp and have the Kenwood drive your speakers directly. Which do you want to do?
Also, do you know how the Kenwood is interfaced to the factory amp currently? i.e. are you using the HU speaker outputs through a line-out converter (LOC)? or are you using the HU's line-level pre-outs (RCAs) to drive the factory amp?
What model Kenwood decK?
Thanks for all suggestions and all is installed and working great.
13
How exactly would I do this for after market amp and since factory is 14 channels how would I get close to the factory amp? I hit a curb on...
4
Please excuse this extra question .. Is there a specified patch lead or compatible bypass harness for the factory amp or would I have to create it...
4
870
Your crossover slopes will be steeper ..so sharper cutoff points ..say deck is 24db and amp is 24db youll have a 48db slope the subs will still...
5
That doesn't make any sense. The directions say to hook it up to the parking brake. The parking brake is engaged when the car is off. You...
17
7K
Tshaffe
Tshaffe
Tshaffe
just call me KeV
    Jun 2, 2024
just call me KeV
    Jun 2, 2024
