how do i hook up a car amplifier to a bookshelf stereo system
i have a rockwood 600 watt amplifier and a phillips magnavox bookshelf stereo system now i have seen them hooked up before but i dont know what would be the ground and what would be the battery because im hooken it up through the ground and the battery connections but where on my stereo would the gound and batter connections be if anyone can help please help me out
You need either a 12 volt power supply or a car battery and a charger to charge the battery when it's dead. Then just connect positive to positve and so on.
every ramos said is right but you have to make shure your book shelf system is the right impedence. or eles you may ruin your speakers
  • running pioneer
    PowerAcustiK
    Target
    Sony
    soon cooming: JL RF and PPI
Originally posted by Avistar23:every ramos said is right but you have to make shure your book shelf system is the right impedence. or eles you may ruin your speakers
  • running pioneer
    PowerAcustiK
    Target
    Sony
This is true. But most home stereo speakers are 8ohm which won't harm a car amplifier at all. The only thing that will happen is you won't get as much power from the amplifier. You also might want to make sure the speakers can handle the power.
128
Got it , LOC black wire actually needed to be grounded . Every video I watched said said it doesn’t and that’s just to reduce noise but apparently...
There is one more thing; you said you will be using the OEM amplifier for the front stage. If that is the case, then you may need an vehicle...
174
If you have multiple amps you do not need to run a power wire from each amp to battery.. You can have a single run of wire with a distribution...
Ill be wiring my next one up at the amps battery bank area and run it to the dash to keep an eye on it
3123000gt
3123000gt
tacoma washington
shibby6615
    Jun 1, 2024
    May 31, 2024
