how do i wire a memphis 500d to 2 jlw3 dual 2 ohm
  • Thread starter <memphis 500d amp help>
  • Start date
  • Replies 2
  • Views 2K
  • 1
Guest
I was wondering how do i wire a memphis 500d amp that is a mono block amp that has two speaker outputs(wired in paralell inside the amp) to two jl w3's dual 4 ohm, into a two ohm load. The amp in not one ohm capable. please help me
It helps to have a multimeter for this just to check after you finish but here gooes.. On each sub take one piece of wire from the negative on one side to the positive of the other side.. you should now have one positive and one negative free attatch speaker wire from those twist the free wires from each sub positive to positive and negative to negative and put to the amp..It only comes out to 4 ohms but if it isn't stable below 2ohms you dont have much choice..Like I said though check the resistance before hooking up to the amp..should be right around 4 ohms.
Mike
Mykeys has got the right idea.
Listen to him, it's hard to get a mental picture in your head just by reading something so draw it out.
the AVIC was a tad more complicated to wire not to mention stuffing it in a smallish stereo hole. thanks for advice.
420
Drill a hole and use the proper protective split loom and hole grommets to keep the outer speaker jacket from knicks and cuts, give just enough...
850
It mostly comes down to weight. You can have a super lightweight cone, soft suspension and aluminum coil on a sub and you pretty much get a pro...
842
Guest
Brendon Jenness
    May 8, 2024
    May 8, 2024
