HOW DO I wire AN 8ohm realistic40-102 and a 4ohm Rockford fosgate S1-84 to a PLA2570?
go get a DMM, turn stereo off and measure the OHM value at the amp's speaker terminal and tell me what it reads.
1.8 ohms.. that's a 2ohm nominal load... not 4ohm!
This is why your amp is still going into protect.
Sounds like its not a good amp to begin with. IIRC thats a Pyle amp. Pyle is synonymous for pyle of ****
edit: why are badwords censored when I say them, but others can drop f bombs all day and not get censored and some even have fewer posts than me.
Well I don't exactly have options yet. This is my first system and its going to take time for me upgrade($) and learn this stuff. For now if it works Im happy, and it doesn't. Thank God for the internet, otherwise Id be screwed. Shizzzzon, how do I make it work with what I got?
This is what I ordered from Amazon. https://www.amazon.com/gp/product/B07MXMPHKS/?tag=caraudiocom-20...
5
123
the AVIC was a tad more complicated to wire not to mention stuffing it in a smallish stereo hole. thanks for advice.
8
627
Drill a hole and use the proper protective split loom and hole grommets to keep the outer speaker jacket from knicks and cuts, give just enough...
8
919
It mostly comes down to weight. You can have a super lightweight cone, soft suspension and aluminum coil on a sub and you pretty much get a pro...
4
892
Henry De Roche
Henry De Roche
Ishpeming, Michigan, United States
AcidicDreams
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
