How many amps do i need to power
  • 4
My63bug
I'm going to be running two Icon 12s 4.5 cubes.. i will be straping 2 zapco st1650 amps. I currently have a 95 amp alternator. I'm going to have to find a thin profile to alternator and Fab up mounting brackets of some sort to make it work. No problem.. finding the right alternator, that I can squeeze to make work for my application and clear my carburetor linkage. Any idea on what would be the minimum amperage of alternator what I need to comfortably Run about 4 k between all 3 amps. (And eventually a smaller air ride compressor)
Lol get some power supplies and bring a generator everywhere you go.
Well arnt u already running one zapco1650 and your electrical is good... double what you got now and you will be good
I've been pleasantly surprised the $ 135 250A Ebay alt I got seems to just about keep up with my amps. I have 2 cheap Lead acid group 75's... Yes I want a Mechman... Etc... but I am drawing A LITTLE current... and this one seems to keep up pretty well. It keeps up except when I try to bleed my ears. How much current can 2 CAB's strapped at 4 ohm be? It's basically a large case GM that claims 250A at 1200 rpm... who knows?.. but it seems to do the job. A lot of people on here hate on it... but I am drawing some amps... How much is open to conjecture but I'm probably putting 1800-2000 into my subs at max...http://i.imgur.com/eZirrn4.jpg ... http://i.imgur.com/ORgaMrJ.jpg ... heck you probably need a 300A.... 4K!
5 ch amps can get expensive and most of the sub stage lacks power for a decent mid-sized sub. And end up running hot. Some times its best to look...
11
Alright sorry this took so long. Here's the update. I tried out all the sets of speakers, the black diamonds did not fit front or back. I think if...
23
4K
This is a little more money but well worth it from looking at the reviews. And it's Korean.
13
I wouldnt waste the time or money on OEM speakers to be placed back into any vehicle unless you plan to sale the vehicle and remove the after...
4
With half inch MDF, it's like 4.27cu/ft internally not including sub and port displacement. That's like 3.5 to 3.8cu/ft after displacement. You...
My63bug
My63bug
Vacaville ca
shredder1
